Fatal Error unhandled e06d7363h Exception at 75fd42ebh
Asked By 35 points N/A Posted on -
Hello there,
I have updated my Windows 7 (x86) and I have this error when I want to open a file, close one or simply when the program is open. I don’t want to reinstall the program because I don’t have the CD anymore so is there any other way to fix this ? What is causing this ?
Thank you !
Fatal Error: unhandled e06d7363h Exception at 75fd42ebh
Answered By 0 points N/A #194029
You can resolve this error by following some easy steps.
1. Uninstall the program from Control Panel "Program and features".
2. Just delete the AutoCAD folder from the program files and confirm that after the process.
3. You must follow the steps from the given article.
https://support.microsoft.com/en-us/help/17421/windows-free-up-drive-space
I am sure it will demolish this problem as soon as possible.
