fenton cruz
10 points
Posted on - 02/26/2012
Please help.
When I click on Layer Property Manager in AutoCad, I keep getting a Fatal Error and then it instantly shuts down my system completely.
Any suggestions would be great,
Thanks!
Fatal error when clicking on Layer property manager in AutoCad
Hello
This is a different problem with AutoCAD and it is quite serious. Maybe this application already sustained several corrupted files that is why you are getting a fatal error and it immediately shuts down your machine. You may try uninstalling and then reinstalling the application and hope it works. This will restore its configurations back to default including some settings that you might have customized before.
If reinstalling it did not even help fix the problem, uninstall it completely then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, Norton SystemWorks, or PC Tools Performance Toolkit. Install AutoCAD again afterwards.
You may also try upgrading your current version of AutoCAD to the latest version.
