Hi I have just installed Kdenlive in my Linux OS and getting error every time when i start and up to now I have been enjoying rather than video editing.
Please provide3 me the solution for the things to get normal.Â
Thank you!
Config Wizard
Welcome
ThIs is the first tirst time you run Kdeniive.This wizard will let you adjust some basic settings, you will be ready to edit your first movie in a few seconds…
Discover the features of this Kdenlive release
Fatal Error
MLT's module not found. Please check your
Cancel
Fatal Error while Installing Kdenlive in Linux
The PC has been a powerful multi-purpose ability tool from its abase beginnings. Unlike many multi-purpose instruments, it can do a lot of matters extremely well. You additional old geezers credibly recollect when hardware was the bounding ingredient, and impatient do-it-ourselfers were continually advancing just to keep step with the software. Then in the former 2000s hardware involved, and at present even cheap goods hardware has more ability than we demand. The benchmark for the exploiter interface has always been windowpanes. This is apprehensible due to Microsoft's lock on the marketplace. Back in the past days of Linux most Linux exploiters came from Unix scopes. Anymore I will stake that the absolute majority of Linux exploiters acquired Windows first, and a goodly number of Mac exploiters also. Which has small to do with orientation and deserve, and much to do with lock up. I began with Mac, then windowpanes, then Linux.
