Fatal error in windows 7 starting.
I installed successfully windows 7 on my pc which p4 Board i865 Harddrive 160GB sata.
After that I used pc smoothly two or four weeks and then suddenly this error appear on system starting screen I do not recognize this error and what is it wrong with my PC.
Error image in attachment.
Please help.
Regards.
Answered By 10 points N/A #83617
Hi.
This is possibly caused by some corrupt or misconfigured file. As you have mentioned that it worked fine for a long time but it is not working now.
I am sure there is some windows file which is corrupt and is required by windows run properly.
There can be several solutions for this:
Try to recover your system to some early date at which it worked fine .
If it didn’t worked then start windows repairing process by using windows CD.
As a last resort, if everything else fails , you have to install a new copy of windows.
But personally I will suggest you to upgrade your system for using windows 7.
It will give you better performance.
