Fault Remarks Didn’t read XML data
I was managing FileZilla Customer a while ago, it is operating well. These days I get one concept: "didn't read:
"C:accountRonnieApplicationfileRunningFileZilladesign.xml": Failure to read XML data". IF I press "accept" I receive.
"Didn't read.
"C:accountRonnieApplicationfileRunningFileZillaqueue.xml", the queue can't start. Failure to read xml file".
If I press "accept" I receive.
Cannot opened file.
If press "accept" I receive.
"C:accountRonnieApplicationfileRunningFileZillaqueue.xml" (error 5: entry rejected) Note: Filezilla format shown at this moment) then the violet concept box appears and stated "failure to read XML data" If I press "accept" a pink pop up it vanishes.
Error writing xml file
Could not write “C:UsersRichardAppDataRoamingFileZillalayout.xml”: Failed to write xml file
OK
If I press "accept" problem thoughts the arrow pointing the filezilla structure. If I press on any data or files features the information in the directory but a pink pop up the screen shown that stated and other problem thoughts shown and stated "failure to start XML data" then vanishes. But another pop up shown stating that: "could not open data"
'C:accountRonnieApplicationfileRunningFileZilla.xml' fault5: entry rejected) Seems I could routine declining the versions and it reacts, however I continue receiving the last data to start ideas. I removed the FZ software applying the screen user interface and download again the clean duplicate. The same element occurs. Anybody would like to suggest?
Thank you.
