jdaniels
10 points
Posted on - 02/21/2012
Hi!
I have recently installed EA Sports FIFA Manager 10 on my computer and I'm really excited to start playing. Unfortunately, I keep getting the following error when I load the game:
Could not load the DLL "GfxCore.dll"
Error Number "126"
Error Message "The specified module could not be found"
I have already reinstalled the program and replaced the previous dll with the latest one but those didn't work. The game won't start. Please tell me, what should I do? I badly need your help. Thanks a lot!
Faulty installation of FIFA Manager 10
Dear Jdaniels,
Please follow the below mentioned steps to fix the issue.
Method 1:
The file can be found in the game’s main directory. Take a backup of the file GfxCore.dll and store it in a different location on the system.
Delete the file and start the game again.
Enter the Game’s DVD into the disc drive. Browse the files to look for the file named fm09_02.zip.
Extract the above mentioned file using winzip..Replace the file in the Game’s main directory.
Start the game again.
Method 2:
It might be possible the specified dll has not been registered properly. Hence try registering the dll file.
Open the command prompt screen by typing cmd in the Start > Run. You should either use CD to change to the relevant directory (folder), or enter the full path to the file.
Use the below mentioned command in the cmd window to Register the GFxCore.dll file
regsvr32 GFXCore.dll
Or
regsvr32 <path><filename>GFXCore.dll
