Favorites, ActiveX, and JavaScript Missing
The Favorites, ActiveX, and JavaScript are missing in my Internet Explorer.
This happened after my computer suddenly crashed while using Internet Explorer.
What might have happened?
Dear,
Sorry for the sudden crash of your computer.
It seems that during the crash computer temporary memory fails to save your working components.
As the memory crashed so it lost some data. You can download and install ActiveX from reliable sources in internet.
Better you keep a backup of your important data on a disc or on other portable device.
Thank You.
There doesn't seem to be a defined computer problem in your case.
There is a chance that while using internet explorer,your computer might have been infected by a virus,thus the loss of such features.
The easier option is to download free internet explore from the internet.Make sure you uninstall the original and install the new one.
Check here for more information,and also see on how to install and repair windows explorer.
