Dean Jones
Posted on - 08/05/2016
Hi. I am a worker in an office based in Delhi. Recently, I have started working with clients abroad and there is a lot of faxing work involved. I would like to know the steps to fax from computer to fax machine free. Please reply ASAP. Thanks in advance.
Fax From Computer To Fax Machine Free And Reduce Your Work Load
Hi. There are three ways to fax from computer to fax machine free which are as follows-
1) You can activate the internet faxing by –
• Click on start menu and then select the control panel
• Select programs and features and then click on turn Windows features on or off
• Click on print and document services and then select the option of Windows fax and scan.
Click on OK
2) You can register yourself with the Internet fax service
• Open the browser and go to the internet fax service website
• Select the registration option and then when the details are asked for, type them to set up a subscription
• Activate the Internet fax service on your PC when asked for.
• Select the run option followed by the allow option to enable the installation of the registration file on the computer.
Then click on OK
3) Send fax using MS Office
• In MS Office, open the document
• Select the office button which is present at the upper left corner of the screen
• From the send menu, click on internet fax option as a result of which an email will open up containing of an image as the attached file
• In the “to” section, type the number of the recipient and then click on send option.
Hope we helped.
