Fax messages computer receive send
You need to install fax modem card on your computer, have reliable internet fax service of fax software,configure your operating system so that it can permit sending and receiving fax messages. Many of computers have installed fax modem card initially. To check whether your computer has fax modem card installed, click "modem" tab and you see the list of installed modem.After you have made sure that your computer has fax modem, click the menu command that allows your computer to start accepting and sending messages.Like an email, it is easier for you to send and receive fax. You can attach the documents you want to send like an email.
If you don’t want to purchase a separate fax machine with a built-in printer to send and receive fax messages, you can also do these tasks from within your computer. But I think you need to purchase a fax software to accomplish this as well as a fax modem if your computer still doesn’t have this hardware installed. It will not be possible to send and receive fax messages without these things installed on your machine.
First thing to do is to check whether your computer already has a fax modem installed.
In addition, Windows Fax and Scan software is already included if you are using Windows Vista Premium or Business Edition.
