Fear 3 — where to find saved games?
I'm almost finish with FEAR 3 game in my laptop. I tried to check on the saved games but I can't find it. Please help on my issue on Fear 3 — where to find saved games.
Hello Green,
Are you looking for the game on your computer after downloading it, or after you installed it. If you just downloaded the game and you cannot trace it, you can go and check in the downloads folder under documents, or check in the programs folder under downloads in documents. You can also install AvaFind and then use it to search for the game on your computer.
Nicke
You can find the saved game in your steam folder location just like in :
If these locations do not work, also check Program Files folder instead of Program Files (x86).You can copy the required saved file from these locations.
Hopefully this will help you out.Â
