Feature, Installation and Download Ovi source
I have downloaded Ovi source and installed  in my computer but I can't connect it with internet.Â
So what should I do?
And what are the advantages and disadvantages of the Nokia Ovi suite?
Hi Asifjoardar,
Hope that my message finds you well.
First you should know if you are using Bluetooth or a connection via USB, you can do this from the Tools menu.
The connection becomes visible on the home view of Nokia Ovi, and you should check that you are not connected to the wired or WiFi network.
About the advantages, form my opinion it depends from person to another because everyone look from his side.
The disadvantages, I heard from some people that there will be a problem with the Multimedia messages (MMS) and the videos on the other hand some people say that the calendar does not display with Ovi.
For some people it is worse and for the others it crashes and that’s made it not a useful application.
Hope that this will help you.
Thanks,
