Hello Guys,
I am doing some important work in MS Word these days. I need to put one of the images in it (downloaded from internet).
But when I try to drag or paste the image in Office window I come across the error message which states:
The feature is not available. For more information,contact your system administrator
I need to paste it on an urgent basis. I will be really pleased if you give any solution within one-two days.
Please help me as soon as possible!
The error message you are receiving means that you are asking MS Word to do something that does not exist in that MS Word. We need to find out why it does not exist, so –
Which version of Word are you using? If you are using your new computer and the Word you are using is called Word Starter, it is not a full version of Word. It is a simplified version that has come preloaded on your computer.
Because this version is simplified, it does not come with a lot of components that come with the full version of Word.
The full list of what is and what is not available is here: Word features that are not fully supported in Word Starter
To upgrade Word Starter to a full version of Word, you need to go to the home tab and then click on purchase. You can also purchase a version from Amazon.com for less expensive and just insert the activation code.
Also make sure all of the upgrades are installed, too.
Have you tried downloading the image into MS Word from the file instead of dragging and dropping?
Insert -Picture – From file:
Hope this helps.
