Features and compatibility of the Fund manager program introduction?
I am planning on purchasing a portfolio management software. I would like to know the features available in  the Fund manager programme introduction and its compatibility with various operating systems like Window, Linux, Mac.
Answered By 0 points N/A #129731
Hi Charles,
The software you are looking for has three versions. The detail features of all the version can be read from the following link:
https://www.fundmanagersoftware.com/features.html
And furthermore a comparison between all three versions is also available on the following link:
https://www.fundmanagersoftware.com/versions.html
AS for compatibility, this particular software is compatible on all version of windows from Windows 98 to later, which includes Windows 98, ME, NT, 2000, XP, 2003, 2008, Vista and Windows 7. The software can run on both 32-bit and 64-bit version of Windows.
For checking compatibility with Linux and Mac refer to the following links:
https://www.fundmanagersoftware.com/faq_linux.php
https://www.fundmanagersoftware.com/faq_mac.php
Hope this helps.
