Features Of The Android 5.0 OS Version
Hello, my name is Frankie. I would like to know the new features of Android 5.0 which is also known as Lollipop? I would be happy if you can give me twenty of them at least. Comparing the latest Android OS version with the Current iOS version of Apple, to what extent has the Android Operation System developed to? What are the basic requirements for a smartphone or tablet to run Android 5.0 Lollipop?
Answered By 590495 points N/A #189864
With Android 5.0 Lollipop, you will have a design that is colorful, bold, and a responsive user interface (UI) for constant, instinctive experiences over all your devices. The responsive, realistic lighting and shadows, natural motion, and familiar visual elements allow it for easier navigation in your device. It has new ways on how and when you receive your messages. You will only get interrupted when you want.
You can read your text messages as well as reply to them directly from your lock screen. For lesser interruptions, you can activate Priority mode using your device’s volume button so that only specific people and notifications get passed. Incoming calls will not interrupt you from what you are doing whether you are playing or watching a video on your device.
You can select whether to answer the call or just continue what you are doing. Android 5.0 Lollipop features a battery saver which lengthens the use of your device up to 90 minutes. When you charge your device, it displays the estimated time left for a full charge. The battery settings also shows the estimated time left before you need to charge your device again.
