The features of App opera mini free nokia c3
Hi, I have downloaded an application opera mini5 for my Nokia C3. When using the app opera mini free nokia c3 it is creating some problems. Why it occurs like this?
Hello Jackie,
I believe that you are using an old version of Opera Mini for your mobile. Older versions often have bugs and sometimes are even unstable. You didn't mentioned what problems Opera Mini is creating for you so it's hard for me to advise.
Regardless, I suggest you to delete your Opera Mini 5 from your mobile and install this newer version:
Newer versions often increases stability and bugs are reduced to a minimum.
Hope this solves your doubts.
If Opera mini is not working on your Nokia C3, you probably downloaded a version that is not compatible with your phone. Try opening this link without quotes on your phone’s browser to download Opera mini: “http://m.opera.com/”. The link should be opened on your phone not on your computer. See if this fixes the problem. Another way is to download the Java file directly (*.jar).
Download Opera mini 8 from the Opera website. The site is not viewable on computer since it is designed for mobile phones so I had to download the JAD file (*.jad) and view its contents since it is a text file and I copied the download link of the JAR file from the inside. Try this and it should work if it is compatible with your phone.
To install the JAR file, just copy it on your phone and open it and it should install automatically. I have a Samsung Champ GT-C3303i which is a Java phone and I tried this Opera mini 8 and it worked.
