Features In The Best QOSRouter For VoIP
Which is the best QOS router for VoIP? What makes the DrayTek a better choice for the SMB VoIP switches? What are the features in DrayTek Vigor2925Vac?
DrayTek's Vigor2925Vac is not just a top-decision for SMB VoIP switches, it's the main such switch to incorporate 802.11ac Wi-Fi. DrayTek banded together with ABP Tech to grow extremely broad QoS for VoIP. Among the numerous VoIP-custom-made elements, the Vigor2925Vac can identify VoIP activity (SIP and RTP media) and naturally give it first need over other movement. QoS is likewise consolidated with proactive transmission capacity administration, so when DrayTek switches identify a VoIP call, they save data transfer capacity for two more VoIP calls than the present number of calls. So transmission capacity is dispensed to VoIP powerfully, is still accessible for different applications when there are no VoIP calls. Double Gigabit Ethernet ports give association failover and load adjusting.
Setups are performed however a Web-based administration interface that is intended to be sufficiently natural for non-IT individuals to get the Vigor2925Vac up and running.
