Mark E Ward
30 points
Posted on - 05/21/2013
Can anyone tell me the difference between the features of free forum software vs Commercial Forum software? I just got this doubt as I see many good Free forum software are available like MyBB but still people prefer commercial forum software ( for example vBulletin )? Your views will help me to select the right option.
Features of a commercial forum software
Hello Mark E Ward,
I am going to make some points regarding Free Forum Software and Commercial Forum Software.
Free Forum Software :
Pros: 1. Free to use
2. Most of them are Open Source .
3. You can customize any open source and fix error and customize in your way
Cons: 1. You have to consider any error or bug you face
2. Don't get any extra support that can a company do after sales.
3. Not easy customize any open source code
Commercial Forum Software:
Pros: 1. Support from company
2. Fewer errors.
3. Special features which is exclusively offered by the company
4. Quality Maintenance.
Cons: 1. Not Free, you have to pay
Hope this differentiation would help to choose the right type of software.
