Features of Dell latitude XT3 laptop
The new Dell XT3 laptop which is said to be of enterprise class, how much is the price of this device and what is its approximate weight?
Dear friend,
The Dell Latitude XT3 laptop is truly an enterprise device. This device cost roughly between $1950 and $1960. The laptop weighs approximately 4.46lbs which is also 2.02 in kilograms. It has the dimensions of 12.7 inches as the width, height of 1.2 inches, and 8.7 inches of depth. This device is extremely light in weight putting into consideration that the device uses a 6 cell battery source. This device is affordable and highly recommended for professional users. It is chiefly designed to the satisfaction of the professionals and business users. I highly hope that this information was of great use to you. Thank you.
Regards!
The Dell Latitude XT3 ships with 64-bit Microsoft Windows 7 Professional powered by Intel Core i5-2520m 2.5 GHz processor, 4 GB RAM, 128 GB SSD hard drive, and a graphics adapter with 64 MB video RAM. It has an 8x external DVD writer. The normal screen resolution is set at 1366 x 768.
It supports Bluetooth 3.0 and Intel Centrino Ultimate-N 6300 802.11 a/b/g/n Wi-Fi. The 4 GB RAM that is originally installed can be upgraded up to 8 GB max. It weighs around 5.2 pounds and will go up to 6.6 pounds if the second battery is included. The touchpad size is about 3.1 x 1.6 inches.
This laptop is originally priced at $2,108 from Dell Small Business. Here’s the verdict for this laptop. For the pros, it has a durable design with screen viewable even when you are outdoors. It has the best performance including the SSD plus the great sound and solid keyboard. For the cons, it is very expensive plus the fact that it is heavy and the touchpad is so small.
Notifications
