Features For Paragon Backup And Recovery 14 And Its Specifications
Hello, notify the features for paragon backup and recovery 14 and its required specifications as well. Reply ASAP and thank you for looking.
Hey, the required specifications for the paragon backup and recovery 14 consist of 300 MHz of processor or more than that. It consists of the Intel Pentium or whichever is compatible too and has Ram of 256 MB or more. The required HDD space must be more than 100 MB only. Below show sits key features:
• It has many filter options too.
• Have backup job wizards as well.
• Can also back to the networks also
• Have many other backup strategies too.
• Can slits the backup as well.
• Easy to use and simple GUI too.
Paragon Backup & Recovery 14 is a backup solution that allows you to have full control over the safety of your computer. The free edition is based on Paragon’s commercial backup and recovery application and doesn’t require any registration.
It supports Windows 2000 Professional Service Pack 4, Windows XP (Home or Professional edition) Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. It requires 300 MHz or faster Intel Pentium or equivalent processor, 256 MB RAM, and 250 MB hard drive space. Supports Microsoft Internet Explorer 5.0 and higher.
64-bit versions of Windows 2000 Professional, Windows XP Home, and Windows 10 are not supported. Supported file systems include NTFS versions 1.2, 3.0, and 3.1; FAT 16; FAT32; Linux Ext2FS; Linux Ext3FS; Linux Ext4FS; Linux Swap; and Apple HFS+ (limited read and write access). Backup features include:
