Features For Permissions Analyzer For Active Directory In Brief As Well
Hello, notify the permissions analyzer for active directory and also mentioned its key features for it. Reply soon and thank you.
Hey, the permissions analyzer for active directory is a combination of the file system with the users and the data groups respectively. The data is stored in the active directory with the local databases and is used to retrieve or to create the permissions to the user or the groups. Below shows its key features:
• It scans all the NTFs file systems easily.
• It has the 3 party integrations as well.
• Has the feature of tracing the users and the groups also.
• Has auditing of the server permissions too.
• Can also modify the server’s permission easily.
