Features for a Good Laptop
Good evening everyone.
I'm planning to buy a new laptop for my office works such as making presentations, spreadsheets, documents and other more.
What are the features that I should be looking at when buying a good laptop suitable for my job?
Best Answer by banglamig
Answered By 0 points N/A #100374
Greetings,
You want to buy a laptop for your office work, so you should buy a laptop which can give you long time charge backup.
Because you need to carry it everywhere. So you should buy a laptop which have long time battery backup.
You should also look nice color, i think black is best for standard color for official use.
You should check hard disk capacity, RAM capacity, Processor version, Motherboard etc too before buy a laptop.
I think you may choose a famous brand laptop for stay safe from any unwanted problem.
HP, DELL, EPSON, SAMSUNG is well known brand for laptop.
Answered By 0 points N/A #100375
A good laptop is the one on which all you need for a particular programs is given, and a good laptop will depend on what it is use for, meaning what will be the objectives on buying a laptop, what will do on it, and what is the main purpose of getting a laptop.
You can use a laptop for gaming, if that's the use of your laptop you have to make sure you will buy a laptop with a higher quality products.
Usually gaming laptop are the one whose high on specs like,memory,processor and other features to enjoy a great gaming experience.If your using your laptop for school there are so many brands for college students with complete features that are needed for doing research and internet browsing.
You also need to consider your budget for the laptop on how much you are willing to spend for the laptop, and also the features you would like to have on your laptop like HD display,Bluetooth,and other programs that are necessary for you to have on your laptop.
