Features on a nokia asha 311
I would like to know the different features that a Nokia Asha 311 mobile phone has and if you can list them for me so that I can better understand the phone.
Dear,
This mobile phone has both 2G and 3G networks.
TFT capacitive touchscreen, 56k colors
240×400 pixels
Memory : microSD upto 32gb.
Internal 140gb, 256bg RAM, 128bg ROM
GPRS, EDGE, Wi-Fi, Bluetooth, USB connections.
Primary camera 3.15mp, No secondary camera, Video supported.
CPU : 1GHz
Battery : Li-lon 1110 mAh
Thank You
The following are the Nokia Asha 311 mobile phone features, starting with the positive features:
Pros
Cons
Carl
Hello Wangui,
The features of Nokia Asha 311 are the following,
1.  It has a very fast processor and they used a 1 GHZ processor for this new Nokia Asha 311.
2.  It has a TFT capacitive touchscreen with a 56,000 color display. Resolution is 240*400 pixels.
3.  It works on both the 2G and 3G Networks.
4.  It supports Polyphonic, WAV and MP3 format sounds. It has a 3.5 mm audio jack for you to connect your headphone.
5.  It uses MicroSD card and it can be extended up to 32 GB and it has a 128 MB RAM.
6.  It has supports for GPRS and EDGE connectivity. It also Supports Wi-Fi connection.
7.  It uses the Bluetooth v2. 1 and MicroUSB v2.0
8.  It has a 3.15 MP camera and the highest image resolutions are 2048*1536 pixels and it supports VGA quality video.
9.  SMS, MMS, Email, and Instant Messaging everything is on the phone.
10. There are games on the phone and you can download games from the web.
11. It has a stereo FM radio.
12. It supports J2ME software.
13. It has a Lithium ion battery which has a stand by time up to 696 hours on 2G networks and up to 768 hours on 3G networks. Talk time is up to 14 hours on 2G networks and up to 6 hours on 3G networks. If you listen to music then the battery will give you support up to 40 hours.
14. The phone comes in different colors, Dark Grey, Rose Red, Blue, Brown, and Sand White. It has a MP3/WAV/WMA/AAC player for audios and MP4/WMV player for videos.
Hope this information will be helpful for you.
Paul.
Dear Wangui
Nokia Asha 311 has been yet another touch screen phone by Nokia. It has the following main features.
1. It has a Corning Gorilla glass display with 56 K capacitive touchscreen and 3.0 inch display.
2. Although it has internal storage of either 140 MB, 256 MB ROM, 128 MB RAM but it supports micro Sd card up to 32 GB.
3. It has a 1 GHz processor that makes it a fast phone.
4. It has a 3.15 Mp camera that supports VGA.
5. It's available in different colors like Dark Grey, Rose Red, Blue, Brown, Sand White
6. It has a very good talk time of about 14h (2G)/ 6h (3G) along with standby time of about  696 h (2 G) & 768 h (3G).
7. Its music play time is about 40 hours.
8. It has all the features you want like memo, predictive text input, organizer, MP3 player, MP4 player, stereo FM, Downloadable games, SMS, MMS, Email, IM, Internet, etc.
Overall it’s a good phone 🙂
Nokia Asha 311 has some excellent features. It's really an amazing phone. The features are-
2G and 3G network
240×400 pixels Screen resolution
3.15 MP
MicroSD card, Up to 32 GB
Bluetooth and Wi-Fi
You will love it. It’s a great phone.
