Features Of Dell Latitude E6420 Laptop In Brief.
I am buying the new Dell Latitude e6420 laptop online. I want to know the features of the device before hand. What are its fascinating specifications?
Dell Latitude E6420 has the 14 inch LED screen with the HD display. It is powered by Intel Core i5 dual-core processor. There is Intel HD graphics and it has 4 GB RAM which can be expanded upto 8 GB. The 9-cell battery which is quite durable gives the power to the laptop. You can purchase the laptop for the starting price of $1284. You can buy the second hand laptops from eBay for the lower prices.
The Dell Latitude E6420 laptop ships with 64-bit Microsoft Windows 7 Professional and runs on 2.67 GHz Intel Core i5-2540M processor, 4 GB RAM upgradable to 8 GB, Intel HD Graphics 3000 video card with 64 MB video RAM, and 320 GB SATA hard drive. It measures 13.9 x 10.25 x 1.25 inches and weighs 6.2 pounds with 14-inch widescreen display at 1366 x 768 pixels screen resolution.
It has built-in Intel Centrino Ultimate-N 6300 Wi-Fi 802.11a/g/n, Bluetooth 3.0 with EDR support, HDMI port, Ethernet, three USB 2.0 ports, one USB/eSATA 2.0 combo port, ExpressCard/54, Smart Card, SD card reader, VGA port, and 8x DVD-ROM drive. Standard battery rundown time is about 8 hours 30 minutes. For the pros, it has soft mouse buttons, backlit keyboard which is great for typing, and excellent battery life.
For the cons, it is quite heavy for a 14-inch laptop and the pointing stick is a little bit stiff.
