Features Of Real Time Network Monitoring Software And Its Software
Hello, notify the features for real time network monitoring software and mentioned some of the software’s as well. Thanks and reply ASAP too.
Hey, the real time network monitoring software has the ability to check the status of the network node. Also allows adding the multiple servers to the devices as well. It cannot be stopped with monitoring the network devices. The software such as Manager Engine, PRTG network manager and many others as well. Below show its key features:
• It monitors the critical servers to get the responses.
• It maintains the alert history’s too.
• Can send the email to notify the persons too
• Have email templates for the different services as well.
If you are looking for an application that you can use to check the data usage on your network, you can use NetWorx Bandwidth Monitor. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003 until Windows Server 2016 both 32-bit and 64-bit. This is actually the last free version, NetWorx 5.5.5.
Currently, the latest version is NetWorx 6.0 but unfortunately it is no longer free. NetWorx is now being released as commercial software. License price starts from $29. Please refer to NetWorx Pricing for more information. The latest version is provided with 30-day full-featured trial period. If you want to purchase the latest, go to SoftPerfect NetWorx.
Note: the latest version is limited to a number of computers only depending on the license type you will purchase. NetWorx 5.5.5 can be used on unlimited number of computers. Aside from tracking the data usage of your computer, you can also check the data usage of every user on the computer.
