Features Of Seiko Smart Label Printer 450 And OS Supported Too
Hello, notify the features for the seiko smart label printer 450 and the supported OS too and reply soon for it and thanks for solving it as well.
Hey, the seiko smart label printer 450 can be bought from the online portals such as Amazon or from the official showroom as well. It is present all over the world as well and the price will be approx. Rs 12000 or more. The OS supported are in windows 7/10/8.1 and in the Mac OS also it is supported too. Below shows its key features:
• Its more cost effective
• Easy to use and install too
• Also it automatically imports the address information’s too
• The size is small and easy to place in workstations.
I guess you are referring to the SLP450 model. The Seiko Smart Label Printer SLP450 can print a standard label in just less than a second. It supports Windows 2000, Windows XP, Windows Vista, and Windows 7. It requires 233 MHz or faster Intel Pentium or equivalent processor, 64 MB RAM, 16 MB free hard drive space, and RS232C or USB port.
For Mac, it supports OS X 10.2 Jaguar and up. It requires Intel Core Duo or faster processor, 128 MB RAM, 30 MB free hard drive space, and USB port. The SLP450 model is available in metallic blue color and has the following features:
If you’re interested in buying one, go to Smart Label Printer 450 with 300 Dpi for more info.
