Features Of The Replace Hdd With Ssd Desktop And Its Steps As Well
Hello, notify the features for replace hdd with ssd desktop and its steps too and thank you for solving and reply asap as well.
Hey, the features of replace hdd with ssd desktop included key elements such as external enclosure with the case. Its dimensions will be 7 mm to 9.5 mm respectively. It will be shock resistant as well and can be easily purchased over the online portals too. Below shows its steps:
• First remove the screws of the computers cases and have access to the SATA port.
• Now put the SSD in the bracket and screw it.
• Next connect the L shaped SATA cable to the SSD with other end to the SATA port.
• Later switch on the PC and run the windows OS simultaneously.
• It’s done successfully.
