Fedora Domain Join Error 0x0008O046: System Restart Required
I'm on fedora 11. It says to reboot. Although I'm only able to login through root.
I've already put my computer in ad domain. I'm using the default domain and 64 bit version.
How can i join using my user instead of root?
Help!
Thank you.
Warning: System restart required
Your system has been configured to authenticate to Active
Directory for the first time. It is recommended that you restart
your system to ensure that all applications recognize the new
settings.
Details
Error code: CENTERROR_DOMAINJOIN_WARNING (0x00080046)
Backtrace:
main.c:283
