Fedora installation Error: Unable to Mount Filesystem
Hi there,
I am successfully practicing Linux using a live cd of Fedora 11. After getting to know how operating Linux works, I decided to move it to hard disk, so that I can use it as a primary operating system on my personal computer. The configuration of my personal computer is INTEL Pentium iv 3.4 GHz with hyper threading technology and 1 GB of ram and 320 GB of hard disk and NVIDIA graphic card.
The installation every time begins smoothly and runs till completion of copying installation files to the hard disk. After that, I got the following error and everything goes finished without a successful installation.
An error occurred mounting device /dev/sda1Â as /:mount
cannot continue.
Press <Enter> to exit the installer.
Your help is required in this regard.
