thejoker
Posted on - 09/30/2011
Not long time ago I installed linux's Fedora os on my netbook Samsung n150, everything was okay but the wireless card, i found drivers for my "atheros" wireless card and installed them successfully on my np150 but it says that it's disabled by the administrator, I am the administrator and I've never disabled it, so I don't really know anything about how to make it "enabled" so i can use it.
Fedora Linux Wireless card problem!
Option 1
To be able you to "enable" the installed linux's Fedora on your netbook Samsung n150. Try these following steps: First, find the "Network" icon of your Fedora desktop. It's icon was a picture of two computer whereas the one was display on the top of the another computer. Second, right click the "Network Manager" icon . And lastly, click the "enable wireless". Try to do these steps it can fix your problem.
Option 2
Check the following:
First, Besure you were connecting to the right network this is when there is more than one detected by the network manager; Second, There must be enough level of strength when connecting to wi-fi. Third, there must be a right authentication. See it on the network manager menu. And last, all must be correctly entered including the WEP index and Authentication types.
