Felix Error – WordInterface on automation server failed
Using Felix with Office 2010 on files downloaded from the Internet Office 2010 has a new feature called Protected View. This protects you from potentially dangerous files downloaded from the Internet. If you open a file in Office 2010 that was downloaded from the Internet, you’ll see something like the following warning at the top of the document. Have any one solution to fix it?
One of the effects of this protection is that it disables all macros and add-ins, including Felix. If you try to use Felix in this state, you’ll get the following error:
Error: COM Error Action: Looking up next segment COM Error Call to Felix. WordInterface on automation server failed. COM error code: 0x80004003 Error: Invalid pointer
