Ava larry
10 points
Posted on - 12/12/2012
Hi to everyone,
A few question about converting pages to doc. The head of our company told me to convert eight two PDF files in to doc. I cannot afford to encode manually all the PDF files within three days, so I need some help from you experts. Can you give me some ways to convert those PDF files into doc? My current OS is Windows XP.
Your suggestion is very much welcome.
Hi Ava Larry,
There are numerous freeware software on the web that will help you to convert PDF files in to doc. Just follow this link to download some freeware software that matches to your need. And install it on your computer. Then you will be able to convert your files using very simple newly installed application interface.
Thanks
1. Solution one:
If you want to convert the whole PDF document into a Word document while preserving the layout and keeping the illustrations, you need specialized software. There is different software, but I suggest you to use Solid Converter which is fast and efficient.
After downloaded, installed and opened, you must browse the PDF document.
2. Solution two:
You can convert them online here.
