Few Step To Know How Do I Find My SMTP Password
Hi. I would like to know about the steps so as to know how do I find my SMTP password in MS Outlook 2010. Is it even possible? Please reply ASAP. Thanks in advance.
Hi. Yes, it is very much possible to find the SMTP password in MS Outlook 2010. The steps so as to know about how do I find my SMTP passwordare-
1) Open the MS Outlook 2010 application
2) Click on the file menu
3) Select the info section
4) Then click on account settings
5) Amongst the options mentioned under it, click on account settings
6) From the list of accounts mentioned, click on your email account
7) Then, select the change option
8) Modify the outgoing mail server(SMTP) to the SMPTP server which was given along with the sign up mail
9) Select the more settings option
10) Click on the outgoing server option
11) Check mark the my SMTP requires authentication option
12) Click on log on using option
13) When you signed up, an AuthSMTP username and password must have been given to you which needs to be input
14) Select the remember my password option
15) Click on OK 16) Click on advanced option
17) Now make sure that the default SMTP port which is 25 has been entered in the outgoing server field and click on OK
18) Then click on next button and once the next window opens up, click on finish
19) Select close in the account settings window
20) Once you are redirected to the main screen, reload the Outlook 2010 and make sure that the mail works fine
Hope we helped.
