Few Steps As To How Do I Get itunes On My iphone
Hi. I want to know how to get your device ready. What are the steps to restore the device to factory settings? How do I get iTunes on my iPhone? Please reply ASAP. Thanks in advance.
The steps as to how do I get iTunes on my iPhoneare as follows-
1) To make your device ready,
• Ensure that you have iTunes of the latest version on your PC. Restore the device.
• Create a backup and save the information on an iPad or an iPhone
• Then, click on settings and then select iCloud. Then, turn off find my iPhone.
2) To restore the device to factory settings,
• Open the iTunes store on the Mac or the PC. However, if you cannot access the computer, erase the memory and then restore the device
• Using the USB cable, connect your iPhone or iPod to the computer
• Enter the passcode if it asks for any and continue
• Select the iPhone when it appears in iTunes. • Click on restore the device under the summary panel
Hope we helped.
