Hi. I have just started working with the DWF file format. I have no idea about it. So, can you guide me a little by suggesting me the steps of how to create a DWF file? Also, how do I open a DWF file? Thanks in advance.
E.Robe
10 points
Few Steps To Know How Do I Open A DWF File
Hi. The steps to create a DWF file are as follows-
1) First open the drawing which is to be used. More than one drawing can be included
2) Click on file menu and click on publish option
3) After the publish dialog box opens, to add or remove the drawings, either click on add sheet or remove sheet option
4) Select the DWF file option from the publish to menu
5) To open the publish options dialog box, click on publish options button
6) In the publish options dialog box, files and password can be entered
7) Click on OK
8) Click on publish button in the dialog box
9) If you want to create the DWF file again, then click on the yes option
10) Click on OK to successfully complete creating the file
To open the DWF file,
1) Double-click on the DWF file
2) If the Autodesk design review is not installed, then click on Program files and select the Autodesk folder
Hope we helped.
