FFIV Launcher problem occurred while updating
When I try to download and launch or setup a new game in the computer I ended up with an error message. For your information, I tried the new game with beta version from the authorized website. In addition, I have Windows 8 64-bit operating system. As per the error message, I tried to restart it but nothing magic happened. Please guide me. Thanks
FFIV Launcher
A problem occurred while updating.
Please restart FINAL FANTASY XIV: A Realm Reborn (Beta Version).
[11006][20641][20643]
Answered By points N/A #188192
To fix this issue, some changes should be made to your PC and the game.
First, disable any useless and troublesome services, for instance, Steam, UPlay, PornHubDonkeyDownloader, Skype etc.
Turn off your firewall and antivirus programs. That is also a great cause that programs fail to communicate with their update server and other servers.
Also, delete the patch file inside “C:UsersYOURUSERNAMEDocumentsMy GamesFINAL FANTASY XIV – A Realm Reborn (Beta Version)downloadsffxivpatch2eeb0f4cpatch” with extension .patch. There is also another folder inside the “C:UsersYOURUSERNAMEDocumentsMy GamesFINAL FANTASY XIV – A Realm Reborn (Beta Version)downloadsffxivpatch” folder that starts with “4b2”.
Delete files in both folder.
Now, run the update work. This should work fine.
