Hi all
I have been a fifa player since a long time now and have been playing it on my system for quite long. Now since yesterday when I am trying to run FIFA09.exe shortcut, an error message appears on my screen and the game totally stops working. There is a blank screen with an error message on it. The screenshot of the error is attached below:
FIFA10-UnlimitedFat.exe
FIFA10-UnlimitedFat.exe has been encountered a problem and needs to close. We are sorry for the inconvenience
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
To see what data this report contains, click here.
If anyone has an idea of the cause of the problem or knows how to fix it, please tell me. Any kind of help will be appreciated.
jones
Fifa 09 error displayed while playing
First thing you need to do is to check for the graphic and video driver on your system.
This game requires graphic driver to be installed in order to run.
Try to update your graphic driver and check whether the problem is resolved.
Also, change your screen resolution to small size.
If the problem still persists then contact EA support.
Thank you.
Hi there user:
The popped-up error only means that there could be something wrong with the application. We’re all aware that games are applications which can be corrupted within a period of time (especially if the game has been modified illegally). This application could be corrupted or (hopefully) just partially damaged. Looking through the error message you posted, it seems like it’s a start-up failure. Try removing the shortcut icon of the game and create a new shortcut. Then launch it again.
I hope this could help you fix your games. In case the solution I gave didn’t work, please post again.
Thanks for asking here at techyv.com
Best regards, Â
