Fifa 11 is getting slow frame rate
I installed Fifa 11 in my pc today but it getting too slow. i think my configuration is high enough to run it well. so tell me how to speed up.
If you have problem with your frame rate than here is some solution. You install it today so you have to know that at first fifa 11 start with pro camera which slow down your frame rate. So you can change your camera to speed up your frame rate to do this go to your game settings and go to camera then change the camera pro to broadcast or any other you like. Now other thing that if you speed up frame rate but want to play with pro camera, OK then there is another thing that you can do go to c drive and then program file that EA sports than fifa 11 then game then fifasetep then run fifaconfig ,game sitting and give all thing to low.
Hi Lamber,
Fifa consumes a lot of memory on your system, and space too. So once you have installed it on your system and your system is running on low memory, you can expect that your computer will certainly slow down.
The perfect remedy for this is to increase the memory on your computer. The memory that supports games well on a machine is always 3GB and more, so you should upgrade your memory to this level.
Hope this helps.
____
Lee Hung.
