There is a problem with download fighter plane game for pc. I am using windows 7 starter operating system and it seems like the installation process did not go through because of some compatibility reason. I hope you can help me solve this problem.
Mellisa Wright.
Fighter Plane Game Not Compatible with Windows 7
Hello mellisa wright,
You are asking about bad effect of fighter plane when download it in the pc. As i know it never causes any harm to any pc if it is legal or download the full version from a trusted web site. When downloading you have to see the file is virus free or not broken. You have to download the game which is compatible to your operating system. If you see the is not installing properly download the precise version for the operating system.
Thank you.
