Figuring out a solution for the incorrect hard drive issue
Can anyone tell how to figure out the incorrect hard drive error?
When the problem about the incorrect hard drive is figured out, kindly describe the method of fixing it?
You can scan and fix a hard drive in few steps. Click on Start menu and open My Computer. Find your hard drive and select Properties from menu. On the top on a menu you can find Tools. Click on it and you will be able to see three options: check now, defragment now and backup now. Choose Check Now. Now you have two options and be sure that you have selected both Automatically fix file system errors and scan and attempt recovery of bad sectors. When the checking is done click Start. You will get message who will ask you if you want to schedule a disk check. Click Yes. Restart your computer. Windows will automatically start running check disk utility.
Hope this will help.
