File art UFO open in Photoshop?
A friend have made an art and have put it in a file that has a UFO format. But now he had sent it to me and I need to open it, but I only have MS paint. Will photoshop open it? Should I buy it?
Good day
A UFO format is a file created from Ulead Photoimpact. UFO contains multiple layers of image data similar to a Photoshop document (PSD). You cannot open it using only MS Paint. You should install a Ulead Photo Impact (now Corel Photo Impact) or other Corel software like Paint Shop Pro or Corel Studio. Please refer to this link.
I suggest you the ''FileViewPro'' which is a program that opens any file you want. It is really flexible and gives you the opportunity not only to open the files but edit them. It is easy to find it, not expensive and has a trial period to check if it suits to your expectations.
