File BOOT.INI deleted from system drive
The file BOOT.INI has been deleted from the root of your NTFS system drive.
What can you do to recover this file?
I recommend you to run System Restore.
It is a recovery tool that helps you to undo changes through the OS.
It is an "undo" element for the largest significant components of Microsoft Windows.
Used to return essential settings and files, like system files, registry keys, drivers and installed programs, reverse to earlier settings and version. It is considered as a step by step wizard.
Make it really simple to decide a point in the history, called a restore point, to revisit your vital settings and file.
Best regards,
Heather marie
Hi there user:
You can use the data recovery software for this problem.
Lucky for you, it’s now available to download.
NTFS Recovery is a utility that recovers formatted or damaged disk.
With this, no need for you to babysit the unit just to learn how to manually recover it.
Also you can partition your system easily using this recovery software to avoid getting confuse of each data.
Thank you for posting your query.
Best regards,
The boot.ini file is important because this file identifies to what folder in which partition and in which drive your Windows XP or Windows Vista is located.
This file can be damaged, corrupted, or even deleted and will surely be brought to your attention if any of these happens.
If you encounter a problem with the boot.ini file, here’s how you can fix it:
