Mike Joseph
30 points
Posted on - 08/06/2011
Hey People.
I Just Downloaded Google Chrome From Google's Website however the installation file does not run.
When I run Chrome.tar.gz An error pops up saying the file cannot be opened as it is not associated with any other program.
Do tell me If you know what should I do Regarding this.
Demmy
Mmatt
File Cannot be Opened Error on Google Chrome Installation
You most likely download the wrong installer for Windows 7. .gz files are used by Unix systems to install applications. Windows is giving you that error that it is not associated with another program is because windows needs the application to be able to handle .gz files.
What you need is the installer that ends in .exe which is the extension for windows installers. You can get it from here:
https://www.google.com/intl/en/chrome/browser/index.html#eula
You need to click Accept and Install (if you accept the EULA after reading through it) and the site will prompt you for the download. Just download the installer, then run it when it completes and it should install successfully.
