File converter from tiff to mov?
I have a bunch of high quality TIFF images and I want to make an animation of them and save them in MOV format. Note that I don't care about sound, I will add it later with Audacity.
Best Answer by George Stacy
Answered By 0 points N/A #143440
Hi Isabellagregorey, I searched some solution that may help you solve your problem.
You may try this online converter for I see no software that directly converts TIFF to MOV but it’s the opposite of it.
All you have to do is to upload the tiff images you have. This free online converter lets you to change the file size, change video bitrate, change audio quality and many other options. After uploading the file and filling the optional settings you are now ready to convert the file. Click on convert file, after the file is converted it will automatically downloaded on your computer.
Click this link for the online converter. Hope this information helps.
https://video.online-convert.com/convert-to-mov
Answered By 0 points N/A #143441
You want to convert your tiff images to a MOV file. A good converter or some good pc commands can do this task.
This link shall help to find them. Here you shall find an online converter.
This is also helpful.
