File converter on word document
Is there any way to convert file from Microsoft Word to .gif format without using any software converter? If not, I should really get a software converter. The question is where I can get that software? Is there only one software to convert that file or there's a lot of them?
Answered By 0 points N/A #104544
Hey joseph Mathews,
Yes there is a way to convert a .doc file to .gif format without using a software it is done using zamzar, to do that simply open up your browser, than type  http://www.zamzar.com/ press enter, when the page opens up, you will find different option, just do the logical steps that is, follow the step,
Under step 1, click browse to select your file, than step2 choose your desired format, step 3 put your email id where you want to receive the new formatted file, step4 click convert. And DONE!
However if you do not find your desired format there, than just download a converter software from www.download.com for free, just enter the key words in the ‘search” and do not worry about which one you choose, cause end result is pretty much the same.
Hope this helps
