File delete error showing while plugged hard drive to Windows Vista laptop
10 points
Posted on - 05/23/2013
I plugged my hard drive to my Windows Vista laptop and when I tried to delete some files, the access was denied because I didn’t have the correct security code. When I tried to change the security this message popped up: “Error Applying security an error occurred while applying security information to: E:…. Access is denied. Should I try changing the Admin account? What do you suggest I do?
An error occurred while applying security information to:
E:
Access is denied.
