elsietbrown
20 points
Posted on - 05/20/2013
Hello. I need some help. I accidentally deleted a folder on my desktop with a lot of JPEG and XLS files. I tried the File deleted recovery Iobit application to recover the deleted files. It recovered the folder but not all the files. Is there any other way to salvage the unrecovered files? I'm on Windows XP 64 bit. Thanks.
File deleted recovery Iobit application did not recover all files
Hi Elsietbrown,
The most effective data recovery software for me over the past many years has been EaseUS. You need to download it by clicking here and choosing "Deleted Files Recovery". Download and then install. After that, you run the software EaseUS and chose the duration back in which you want to recover deleted data, chose drive (location) and then you are good to go. It is basically a fast software in recovery, but it may take time based on the size of your hard disk and the amount of deleted data.
All the best.
