File doesn’t have a program associated error: What are the solutions?
Error message: This file does not have a program associated with it for performing this action.
How do I create an association in the Default Programs control panel?
Step by step procedure will do!
Thank you!
E:
Please install a program or, if one is already installed, create an association in the Default Programs control panel.
Best Answer by Bena Alphjo
Answered By 0 points N/A #141868
Download Default Drive.reg.
First backup your registry follow these instructions.
Click on Start > in search box, type regedt32 and press Enter.
"Registry Editor" will be opened. Click on File –> Export (save it where you want).
Now double click on the downloaded file (Default_Drive.reg)
Click on "Yes or" (Click “Run” if you are using Windows XP)
Finally restart your pc.
Answered By 30 points N/A #141869
Hello.
It seems there are two CD/DVD drives in your system. This problem may be because of the two drives. Try to insert the DVD in the other drive and try to accesses it. If the problem still persists then you need to uninstall one of the drives. If you can accesses the DVD through other drive. Then there will be a problem with your first drive.
Thank you.
