File error when extracting a zipped file
Today, I was attempting to extract a zipped file in a folder but an unexpected error was displayed. I have searched the solution online but I couldn’t find anything. Can I get the resolution from your side? I need your support to handle this issue.
I would be grateful to you.
An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem.
Error 0x80004005: unspecified error
Type: PNG image
Date modified: 9/6/2012 9:26PM
