lor10288
10 points
Posted on - 12/14/2012
I wanted to export my first project in Premiere CS3 as an AVI, however the options shown during export are only QuickTime, flash, or mpeg 2.
If I select QuickTime, will it encode with codec premiere cs3 per file mov?
Then, is there any app that I can use to convert the mov files to AVI?
Thanks,
Lhor
File exported with QuickTime have codec premiere cs3 per file mov?
Hello Lor10288,
I am confidently saying that there is no ultimate difference between MOV and AVI. AVI is just different file format intended for the other purposes. You are recommended to convert from MOV to AVI not because it is worse.
You'd better do it when the media player you use doesn't support the extension of the file.But MOV file takes huge space of the hard disk.
There is a lots of converter software which can perform your task.I am giving references about some of these.
Pazera Free MOV to AVI Converter is a set of built in instructions designed to convert MOV and QT files to AVI and MPG. Once you're done with the installation, you'll find a clean interface that helps the app serve its purpose quite okay.
Just click here
Another one is MOV to AVI converter.
Best of luck
Shifflettttt Laurel
