Hi all,
I have been using Mac and am now on OS X Lion but suddenly my Mac shuts down automatically and just before it goes off I get error 1708 as shown below. I do not want to stop using OS X so please advise me.
Error:- 1708.File Juicer got an error: Can’t continue<event juicjuic>
OK
points
File Juicer error on Mac
Your File Juicer seems very crazy because of showing the error. It has got solution, too.
According to my research, File Juicer v4.9.4 has got this error 1708 fixed. If you are using an older version, it means that this error has not got fix to resolve.
So, get File Juicer that is at least v4.9.4.
The best option will be downloading the latest version.
Download it right from here.
Best of luck.
This is a know error in all versions of File Juicer 4.9.3 and earlier. Try checking for updates for the copy installedon your computer and see if that works. Otherwise, the only alternative to permanently get rid of this error is for you to install the latest version of File Juicer or at the least version 4.9.4 or later.
That error is with the program which is probably running in the background and got triggered because of the sudden shut down of the computer. Restart your computer then try again. If this doesn’t work and you see the same error again, just try updating the program. Go to File Juicer to get the latest.
The latest version at the moment, File Juicer 4.76, supports OS X 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave. For a bit of info, the program is a drag-and-drop can opener and data archaeologist. It is designed to locate and extract images, text, video, or audio from files which are difficult to open in other ways.
It can extract and locate the following file formats from files which contain these data formats:
- JPEG
- JP2
- PNG
- GIF
- PDF
- BMP
- WMF
- EMF
- PICT
- TIFF
- Flash
- ZIP
- HTML
- WAV
- AVI
- MOV
- MP4
- MPG
- MP3
- AIFF
- AU
- WMV
- text
